INN3167 hot start issue
Posted by: Viktor Horbunov on
Issue: some of (few%) devices PSU (12V 2.5A) didnt start after power cycling. Looks like Cbpp still charged, Cbps discharged while applying input, typically its 1-20s after poweroff.
Also - didnt work CC profile.
If PSU started someway - it works perfect, in full range of input voltage and output current. Bug is critical, dead device after grid blinking.
What are already checked:
-bug not visible, if Cout left charged
-bug not visible, if discharge Cbpp
-bug migrated with some transformers (didnt seen differences in measurements, see below)
-Cbps replaced 2.2u-4.7u-10u
-Cout replaced 220u-1000u
-Cbpp replaced 0.47u or 4.7u
-Rbpp replaced 3k, 7k, 10k, 13k
-IC replaced (again, bug is migrated with transformers)
-UV/OV disabled
Transformer data
  Transformer OK Transformer NOK
Primary inductance, uH 563 565
Secondary inductance, uH (half/half) 8,2 (8,13/8,17) 8,14* (8,18/8,21)
Bias inductance, uH 10,2 10,15
Primary leakage, uH, Secondary shorted 23,4 24,5
Primary leakage, uH, half secondary shorted 26,22/26,0 26,1/29
Secondary Leakage, uH, primary shorted 0,35 0,37
Half secondary Leakage, uH, primary shorted 0,4/0,4 0,4/0,44
Phase check, uH, All windings in series 877 880
Schematic data - added.
FWD pin osc view - added (FWD and Cbps voltages while unsuccesfull start attempt, 14 pulses)
Submitted by Viktor Horbunov on 02/17/2026
Here is more complete osc pictures, succesfull and failed startup
Oscillograms of startup, ok and nok (1.36 MB) 1.36 MB
Submitted by dlw on 02/20/2026
Hello Viktor,
Since the issue seems to be transformer related, I would assume it is of common mode nature. Please evaluate dv/dt levels observed on primary and secondary switching nodes, including primary bias rectifier.
Kind regards,
PI-Dmitry
