SPICE Model for TOPSwitch TOP245YN
Posted by: Guilherme Pissaia on
Hi experts,
I would appreciate it if you could provide the SPICE model for the TOP245YN device. I’m currently working on a power supply board that uses this component, and the board is exhibiting some issues that I believe could be better understood and addressed through simulation.
Thank you!
Submitted by PI-Gavin on 05/14/2025
Hi Guilherme,
We are sorry to hear you have some issues. Topswitch-GX is already an old device and we do not have any simulation models for this device. We also pulled out the PI expert for this product so the support will only be limited.
We recommend to use a newer device. We have simulation models for our Innoswitch3 products. You may refer here: SIMPLIS Model for InnoSwitch-3 | Power Integrations
Regards, Gavin
Submitted by qkpcm jwnpfkacm on 05/15/2025
(redacted)
Submitted by Guilherme Pissaia on 05/15/2025
Hello Gavin, thanks for your reply.
Since I'm unable to design a new PCB to use a different device (this is also an old board), I would appreciate it if you could suggest any device that is pin-compatible and functionally similar to the TOP245YN, and that has available simulation models.
Best regards,
Submitted by PI-Gavin on 05/26/2025
Hi Guilherme,
Unfortunately, we do not have any pin-to-pin replacement for TOP245YN.
-Gavin
Submitted by Aliimus on 06/16/2025
You can try to contact AVAQ's support team to see if they have relevant data: TOP245YN
