Quiry for x'former design
Posted by: vaxididaj on
Dear Sir, I am to design an SMPS Transformer in which Input supply - Universal (85 – 65VAC) DC Output - +5V / 0.05 Amp -5V / 0.14 Amp +24V / 0.05Amp (e. g.) Would you tell me, how I am to choose the PI device family, family, Package etc ? In this design, In the Control section IC is TOP242P . Regards Kusum sen Electronics & Automation Systems G1-347, Bhamashah Industrial Area , Kaladwas, Udaipur (Raj.) Ph.No.: 0294-2650695 E mail id : eas@easindia.com
Submitted by prasun on 10/08/2008
( 0.25+0.7+1.2) = 2.15Watts.Use TNY274PN without heat sink. TOP242P would be costly as compared to this. mail me prasunkuls@hotmail.com if any query.
Submitted by husee on 11/20/2009
Hi! I'm currently trying to make this SMPS work properly. The problem is that the SMPS doesn't hold on load. It's expected to be 27-30V/3,2A 96W. Everything is fine until load >20W is reached. Then TOP-switch heats up and I think thermal shutdown occurs (actually not so sure,because on the scope pulses are getting smaller in amplitude,but not disappearing completely). TOP-switch is mounted on proper heatsink, but the heatsink is not very warm (45-50 C),because TOP-switch shutdown occurs in seconds after load is applied. I'm using PCB design and schematic exactly from PI application notes for this device chicago mortgage loans. The feedback consists of optocoupler PC817A and zener diode. Snubber - BYW26C and P6KE200. ~220V input - common mode choke ,10A bridge rectifier,100uF/400V capacitor. Output - Schottky Diode 10A/200V ,1500uf capacitor. Transformer - Kaschke TRFSP-E36/11 067.039 . The Datasheet is a little bit confusing dental insurance. There are two secondary windings 15V/4,5A ? In parallel Question Looking at the pinout of the transformer it's visible that these windings are not provided for in-series connection. So, I'm in a big doubt whether I'm using a wrong transformer. It's intended to be used specially for TOP247. One more thing - the secondary windings' start/end appear to be marked in opposite. If I connect them according to datasheet info - SMPS is "clicking" - it's in autorestart mode /1 click per second/. Looking at the scope is visible that transformer's energy won't dissipate due to the opposite connected winding. Primary and Bias windings are OK chicago investment property. Now I'm testing it using only one of the secondary windings. And lastly - Primary Inductance is 178uH - isn't this too small ? Any ideas and opinions are appreciated ! Thanks ! The 067.039 datasheet shows a single 15V/4.5A secondary winding. I don't know, if the datasheet is corresponding to your part, but I see no unclear points in the datasheet. There's probably incorrect information about the part in an overview catalog, that tells about dual secondary. some of PI PI application notes not working very well..i hvae the same problems with the TOP247 before..many TOP blow's up..
U can setup the OutPut power with two resistors at the TOP.u check this first..but be carefull with this..the transformer can be saturation and the TOP can't switch-off fast checking account..this the problems of the TOP-switch...
for check ur problem i need ur layout and schematic..and the BOM
