change of primary inductance with KP
Posted by: Paul_221 on
Hi everyone,
I must used fixed transform with LP 750uH. Is it right, that i changed it by seting KP=0.89 ? What KP influence in my design(except LP)? Thanks.
Submitted by PI-Spock on 08/10/2010
The value of KP influences the value of Lp as you pointed out. As a result it influences peak current IP also. Higher KP, results in higher IP. Higher KP also results in lower value of NP due to smaller LP.
Submitted by Paul_221 on 10/31/2010
Submitted by Tiny.Wang on 11/27/2017
What the different between the KP and KRP(ripple current IR to peak current IP ratio KRP)?
Submitted by PI-ODO on 11/29/2017
Dear Tiny.Wang,
KP is the general term for continuity factor. KP=KRP for continuous mode, and KP=KDP for discontinuous mode. For specific definitions, please refer to Figures 9 and 10 in AN-32. Thank you.
-PI-ODO
