TNY266 problems
Posted by: ras123 on
Hi, I have designed a DC adapter using PI Expert 7, with the following specifications using TNY266 (DIP Package) I/P:- 120 to 265 V O/P:- 2.4 V / 2A I followed the design except I used UF4007 instead of FR106 (DB). Without any load it gives correct o/p voltage, but when I loaded output with a 10 Ohm resistor, the circuit burn off (i.e TNY266 shorted). The same repeated twice, so can anybody help me to find out the problem? Please see the design attached with this post.
PIDesign.pdf (70.87 KB)
Submitted by PI-Spock on 10/28/2008
Can you attach your design schematic and your layout file? The PI Expert design looks fine and its ok to substitute a UF4007 in place of the FR106 diode for DB.
Also please measure how much leakage you have in your circuit and let me know.
Submitted by ras123 on 10/29/2008
Hi, I followed the same schematics as per the PI Expert design attached. Is the PCB too critical? Can you tell me possible reason for breakdown? Initially I loaded 10 Ohm without the voltage control (i.e. with out 1.4 Volt Zener diode), and it works fine. When I regulated the o/p voltage to 2.4 Volt it also works fine, but while switch on with load (10 Ohm) breakdown occurs. Is any danger to design such low voltage SMPS?
Submitted by PI-Spock on 10/30/2008
No there is no danger to designing for low powers...
From the PI Expert design files I dont see any problems. I may be able to spot something after looking at your schematic and layout...
maybe you have big loop areas, maybe you have too little heatsinking maybe you connected some parts of the circuit backwards (namely the clamp) I cant tell without looking at your schematic and layout
Submitted by smith67 on 04/28/2010
(PSU) is one of the few items in an electrical device that will affect the performance and reliability of 644-141 your entire system. It's often the most undervalued, under-appreciated component within any device, yet one of the first components to cause failure. 646-056 This article focuses on the factors to look for when purchasing a PSU for a personal computer, but it may be applied to any application needing a regulated PSU. 646-102 When following this guide, take into account your own application, and appropriately weigh each factor.
646-222
