INN3164C Mosfet CD value
Posted by: Arge on
Hello PI Support Team,
I am using INN3164C in a project. Can you tell me the mosfet CD value for the transformer formulas? I couldn't find the CD or COSS values in the datasheet.
Arge
Submitted by PI-Heidi on 12/09/2022
Hello Arge,
Thanks for reaching out to us. Please refer to Figure 23 (Coss vs Drain voltage curve) of InnoSwitch3-CE datasheet for the drain capacitance value.
I hope this helps.
PI Team
Submitted by Arge on 12/10/2022
Hello PI-Heidi,
According to Figure-23, when I calculated the scaling factor for INN3164C as 1.95pF, I found approximately 3x1.95=5.85pF for Drain voltage 550V. Can you confirm this?
Could you share the calculation formulas for transformer design for INN3164C?
Arge
Submitted by PI-Heidi on 12/12/2022
Hello Arge,
The drain capacitance calculations seem correct to me.
Regarding the transformer and power supply design, we recommend you to use our PI Expert Online tool [PI xls tool].
Please let us know if you have any questions.
PI Team
Submitted by Arge on 12/12/2022
Hello PI-Heidi,
When using PI Expert, we choose my maximum frequency at minimum voltage and full load for transformer calculation? I'm asking to confirm this.
Arge
Submitted by PI-Heidi on 12/19/2022
Hello Arge,
Yes, the power supply switches at the maximum frequency with full load, low input voltage and minimum primary inductance tolerance.
I hope this helps you.
PI Team
