TOP256YN noob question
Posted by: Tsitsias
Hello all, I have a power supply from a projector that has a burnt TOP256YN AC/DC converter. I cannot find TOP256YN to replace it, can I use TOP259YN ?
© 2026 Power Integrations. All Rights Reserved
TOP256YN has two frequency modes. If frequency pin connected to source, unit switches with 132 kHz frequency and if connected to control pin, unit switches with 66 KHz. TOP259YN has only one frequency mode of operation i.e 66 kHz. Please check your design before changing the device. If your design operates at 66 kHZ , use appropriate resistance on X pin to limit the current based on datasheet. TOP259YN is rated for higher power, so high current limit.
