TNY290PG - OUTPUT LOADING ISSUE
Posted by: anurag lokhande on
HI,
SMPS designed for 12V 2A.  ( Output waveform for voltage is clean at 0.7A load)
Please see results
Input AC Output
Vin I Vout R load Iout W
160 0.07 12.23 20 0.6115 7.478645
160 0.1 12.25 17.8 0.688202 8.430478
Used reference from
--> Application note
Reference Design Report for a 20 W Standby
Power Supply Using TinySwitchTM-4
TNY290PG
Following are observation
1. At input voltage 160V, output voltage goes into hiccup mode when I increase load further
2. If Input voltage increase above 160V at constant load of 0.7A, the output voltage goes into hiccup mode
Please give your advice. Please let me know for any input required for further analysis.
Submitted by PI-BERJ on 08/30/2021
TNY290PG might have gone into overload. Details are in the Auto-Restart section in the datasheet. Is the hiccup duration every 2.5s?
