Top 249YN Power supply 5V8A
Hi guys, please help me! I have problem with my Power supply. I designed flyback power supply used Top249Yn with output 12V3A and 5V8A. But when I put load on output 5V, it was a problem. When load is < 3A, everything is ok, but when load reach 5A or more, Diode TVS P6KE200 heat so strong, and affter 3s, this diode died! ( output 12V this time is no load) - I tried to remove diode TVS, but when I put load 5A to output 5V, IC TOP249YN heat and exploded@@
My primary inductance is 600uH, 70turn, secondary winding 5V is 3turn.
Hi ! Easy Peasy.
Can you tell me some methods that provide reducing leakage inductance?
In my power supply, I just used one method like " sandwiched transformer construction".
Can you tell me how to calculate or measure leakage inductance?
Hi tonycnbel,
You can measure inductance with the use of an LCR meter (same procedure when you measured the 600uH primary inductance). But in this case, you need to short all the other windings (i.e 12V winding, 5V winding, VCC winding).
To reduce leakage inductance, try to use sandwiched construction and minimize insulation thickness in between layers. If possible, minimize the number of layers.
PI-Seven of Nine
Hi, PI seven of nine
Thank a lot for answering me . I try your solution and get the result that Lleak was 30uH. Do you think it's High?
And I put some air gap in ferrite core before, may it do effect on Lleak?
air gap has no effect, you need a 3 or 5 layer construction, Pri-Sec-Pri etc ... a longer bobbin on a slightly bigger core will help too
Hi tonycnbel,
Air gap has no effect. If you gap it while maintaining same number of turns, this will result to lower inductance. You might end up increasing the number of turns just to arrive on the required inductance of the design. Increasing the number of turns might result to additional layers that can increase the leakage.
At 30uH leakage inductance with 600uH magnetizing inductance, this is around 5% which is already low. But if you can still reduce, the better. 3% to 5% is already considered low.
PI-SevenofNine
it appears you have too little coupling between windings on your transformer, i.e. too great a leakage inductance.
