LinkSwitch CV Start-up Time
Posted by: robert.ruchar@… on
Dear Gents, I've designed an off-line SMPS using LNK626 switcher (more details upon request). The supply start-up time is very slow (roughly 3 sec) at DC input voltage about 140V .. 160V. In the datasheet, I found information about auto-restart protection OFF time about 2 .. 2.5s, which seems to be related to the observed long start-up time. The first question is, is it possible to start-up the supply quickly (within tens or hundreds of msec), i.e. without the aforementioned delay ? How can this be done ? Alternatively, can you please recommend a different low-cost switcher for comparable power level ?
Many thanks, Robert
Submitted by PI-Jedidiah on 04/02/2018
Hi Robert,
Do you have waveform that can be shared capturing Vds, Ids, Vbpp, and Vbps during start-up condition? 2.5s auto-restart happens only during fault condition like stated in the datasheet.
Jedidiah
Submitted by robert.ruchar@… on 04/16/2018
Dear Jedidiah,
thank you for the hint. I've been off work for some time, I will check the matter as advised.
Best regards,
Robert
Submitted by robert.ruchar@… on 04/26/2018
It looks like the problem occurs when the input (high voltage) supply ramp is very slow - say hundreds of miliseconds. In that case, something small appears at the output (e.g. 2 volts instead of required 22 volts) very early, but it becomes stuck at that level for the next 2 sec or more (see picture). It looks like that the auto-restart protection is activated. Can I do something to prevent from this behavior ? Many thanks, Robert
Submitted by PI-Jedidiah on 04/26/2018
Hi Robert,
Can you share to me the schematic you are using in your power supply and the transformer specs?
Jedidiah
Submitted by robert.ruchar@… on 04/27/2018
Dear Jedidiah,
I'm uploading the requested items.
Note that the circuit is used as a house-keeping supply within a bigger unit, powered off a bulk cap of a PFC front-end. In some cases (operation scenarios), input voltage rises very slowly (rise time hundreds of miliseconds) and here's where the mischief happens.
Thank you for your attention.
Best regards,
Robert
TI-EF16-4V1-22V-6W5.pdf (754.85 KB) 754.85 KB
Dear Jedidiah,
Best regards,
Robert
Submitted by PI-Jedidiah on 04/30/2018
Hi Robert,
Based from your schematic, it seems you have multiple output. 22V/0.25A and 4.1V/0.25A. Is that correct? And you connect the FB divider resistors on 22V rail. LNK-CV needs an auxiliary winding to regulate the output voltage same as shown in the sample schematic of datasheet. Can you measure also the waveform across 4.1V during start-up?
Jedidiah
