Dual Port Charger with Quick Charge 2.0/3.0 Compliant
Posted by: Hemalatha R on
Hi All,
Lookig for reference design for Dual Port Charger with Quick Charge 2.0/3.0 Compliant, maximum current for overall to be 4A.
Went through DER 494 desgin document it is INNO switch and CHY103 based design .
As per CHY103 datasheet it supports for InnoSwtich , TinySwitch and TOPSwitch
PI Team please clarify on below queries :
1) DER 494 can be used for Dual Port design as well ? if so what are changes in schematics
2) CHY103 with TinySwitch / TOPSwitch 20W Dual port charger design is available ?
Hemalatha
Submitted by PI-DATA on 04/13/2018
Hi Hemalatha,
1. What do you mean by dual port? If it is ok to have the dual port in parallel then yes you can use DER 494. For your customized design you can visit online guide below link.
2. Tinyswitch and Topswitch are not usually used as quick charger applications.
Submitted by Hemalatha R on 04/15/2018
Hi PI Team
Dual port means 2 USB ports, our requirement is to provide quick charger feature at both USB ports.
If DER 494 can be used then what all are changes required in design to use it for 2 USB ports ?
Submitted by PI-DATA on 04/16/2018
Hi Hemalatha,
Yes we know that it is 2USB ports. But what we want to clarify if that two USB ports would be parallel or entirely independent?
Submitted by Hemalatha R on 04/17/2018
ok, it is parallel port .
but i would like to know if it is independent what all are changes required.
interested to know changes in both type of configuration - parallel and individual ( 2 USB ports)
Submitted by PI-DATA on 04/17/2018
Hi Hemalatha,
You can use DER 494 exactly as it is.
For dual port with independent output, you need to have two power supplies.
It will be hard to have quick charger that is coming from a single flyback with a dual secondary.
In this case you need to have two primaries and two secondaries.
For Bulk Cap until the fuse section you could combine it for the two power supples.
