Drain wave form Doubt
Posted by: mohan.n2293@gm…
Hi All,
I have designed a power supply with stack fet configuration,but when i measure the drain current wave from using scope i saw a different waveform ,please see the attached waveform and tell me weather it is correct or any part in power supply need to tune to get perfect waveform.
(391.86 KB)
Hi Easy Peasy,
Please find my schematic.
i had measured the drain current by removing drain pin and prepared loop using wire and tested using DC clamp meter .
| Sheet2.pdf (61.32 KB) | 61.32 KB |
your current waveform looks odd, what are you powering the circuit from?
try using 2 x 1.0 ohm res in parallel in the source to measure the current from ...
Without seeing your actual circuit - it is impossible to comment.
