21V/16A power supply
Posted by: Orion_lai
We are going to design an AC/DC adapter, please see below for details. Would you please kindly advise your comment. It seems that Hiper TFS-2 and Hiper LCS families meet our requirement and I tried to use PI expert suit but it was no solution for these two families.
Input voltage: single 230V
Output: 21V/16A
Energy effieiency: level VI
Orion
Thank you for your advice.
Hi Orion,
What particular application will this design be used? Thank you very much.
Leo
Hi Orion_lai
For this power (336W) you should use PI Expert online (select Application Any, Output Power >100W then select from left HiperLCS and then select PI Xls; in PI Xls in gray cell put your desired value). Hope help. Good luck!
