LNK302/304/306 AC to DC Miniature Circuit
I've read through the LNK302/304/306 datasheet and also the AN37 Application note.
I'm designing a system with AC230 input and 3V3 outpput which needs to be really small, from the circuits provided in datasheet I've found most of the components of smaller size. The only problem is the input capacitors of 400V.
I'm not able to fnd 400V small size capacitors, so is there any application note or using different component the size can be reduced??
The pcb size I'm looking for is 35mmX15mm
Thank You
I've tried sourcing on mouser, element14 and digikey.
Non polarized I'm getting in smaller size, not able to find polarized capacitors in small size.
Hi Praveen,
Have you checked on this SMD caps? See below link:
http://www.nichicon.co.jp/english/products/pdf/2012fpcap_catalog_all.pdf
http://au.element14.com/nichicon/uug1e102mnq1ms/aluminum-electrolytic-capacitor/dp/1899616
Hi Praveen,
We suppose there's a smaller 400V cap equivalent but it will come with a higher price. Have you tried sourcing or researching on different vendors for smaller 400V cap? Do you have restrictions in component height?
