AC/DC with particular Vin extension
Hi, I have to realize a AC/DC device, 12Vout or 5Vout ,near 5/7 Watt output, with Vin: 20Vac or 20Vdc minimum and 240Vac/240Vdc as a maximum input Voltage
Vout must be isolated. Can You help me about a possible solution ?
Features: must be very little and as component are necessary (should be
better) that these components are available in FARNELL odr DIGIKEY or MOUSER and so on. Could You help me ? Thanks
sir can you tell me how to change default setting of PI ic selection, in software there is tny274 is deafult setting but i want to select tny280 by default can you help me with this
Click on the device symbol in the PI Expert schematic for your design. A new window will pop-up which allows you to reselect the PI device.
Hi FG,
Kindly use our PIExpert online tool to generate your required design from the given conditions.
Or you may the design examples from our website that closely match your requirements.
PI-Picard
