TOP-GX activation key (to extend support in PIXls)
Version 9.0.9
TOP-GX does not seem to be supported in PIXls (on or off-line version) or PI Expert (Online version) despite the PI website saying that is.
When starting a new design if you scroll down to the TOP switch options you are only given the choice of TOP-HX or TOP-JX.
I need to produce a 40W design with good Power factor so want to use the TOP-GX family.
Please advise!!
Have the same problem. Install version 9.0.6.3. GX supported in Expert and Xls. In 9.0.9.1 GX supported in Xls only.
Hi vladi, davidrose, and others,
Based on your input and that of our other customers, we have created the following TOP-GX Activation Key: 4912B6C609
After logging in to PI Expert Online (https://piexpertonline.power.com/), the key can be entered on the Main page by clicking on the Activate product key button.
The key works for PIXls designs only.
The key should be activated before 06/16/2017 (after which users cannot activate the TOP-GX with it, but users who did so already will still be able to continue using this product forever).
Please note that the TOP-GX has been archived on our website because it is not recommended for new designs. In an effort to minimize the inconvenience of transitioning to TOP-HX and TOP-JX designs, however, we are offering the special key in the meantime.
-PI-ODO
Unfortunately, the TOP-GX product has been archived and the spreadsheet is not available for public use.
