SMPS 24-240VAC/DC?
Posted by: PatrickB
i will build a Powersupply with a single ultrawiderange Input 24-240VAC/DC up to 15W, with a single output 24VDC
Do you offer a solution for this?
Patrick
It is interesting if customer can use 24VAC/DC up to 240 VAC without change anything or avoid destroy the application
Additional there is a galvanic isolation between main supply and analog signals like 4-20mA
I wonder what is the application which needs to work with this wade range of Vac. Becuase it will not end up with the cost effective transformer design.
Currently we don't have IC can directly work with such low Vac. It is interesting that your application need such wide range. May I ask what is the application? and what is your target topology?
