SMPS 24-240VAC/DC?
Posted by: PatrickB on
i will build a Powersupply with a single ultrawiderange Input 24-240VAC/DC up to 15W, with a single output 24VDC
Do you offer a solution for this?
Patrick
Submitted by PI-Neela on 03/28/2016
Currently we don't have IC can directly work with such low Vac. It is interesting that your application need such wide range. May I ask what is the application? and what is your target topology?
Submitted by PatrickB on 04/07/2016
It is interesting if customer can use 24VAC/DC up to 240 VAC without change anything or avoid destroy the application
Additional there is a galvanic isolation between main supply and analog signals like 4-20mA
Submitted by PI-Neela on 04/19/2016
I wonder what is the application which needs to work with this wade range of Vac. Becuase it will not end up with the cost effective transformer design.
