LinkSwitch II electromagnetic susceptibility problem
Posted by: denyslk on
Hi, we are using a Linkswitch II (LNK606DG) in our power supply, and all seems to be fine, except when we go to the electromagnetic susceptibility testing.
When the power supply is affected by an external magnetic field at frequencies around 134MHz, the power supply dies and even if the RF field is shut off after that, the power supply still doents recover and need a power shutdown and restart to make it work again.
we use an isolated flyback topology with a transformer having an AUX winding for regulation.
the output is 24VDC.
our circuit is based on the datasheet app note (datasheet page 4 circuit)
https://ac-dc.power.com/sites/default/files/product-docs/linkswitch-ii_family_datasheet.pdf
any suggestions?
Submitted by denyslk on 04/12/2016
I think its 12th harmonics of the main switching freuency which is about 65 - 66 KHz, now the question is how to protect the IC from being affected by this harmonics, and avoid IC shut down when the rf field is applied near the ic.
Submitted by cuongcdt2 on 04/14/2016
Hi, i want to design 12V/30W power, the schematic is already base on the reference. My problem is i don't how to choose the transformer.
kind please helf me.
Cuong
Submitted by PI-NANO on 04/15/2016
Could you please send me your Schematic, PIXls design and PCB layout so that I can take a look at the design.
PI-NANO
The attachment is a reference schematic, How i can choose the switching transformer for this design?
What conditions are readly need for the switching transformer? can I choose transformer base on Power and Volatage out or other conditions?
Cuong
Schematic (92.37 KB) 92.37 KB
Submitted by PI-NANO on 05/11/2016
Hi cuongcdt2,
This is someone else's post.
Please post your question in a new post, so that things don't get mixed up.
PI-NANO
