PI device to take a 30-240VAC input to a constant 24VDC 50VA output
I have a generator with a 8:1 voltage output. If required, we can rewire this generator to either lower or raise the voltage, but it will still be 8:1 due to the RPM range that we must accommodate. This is a 3 phase generator. The DC voltage listed below is generated by running the AC voltage through a Bridge Rectifier. We DO NOT have to use this Rectifier. What is critical is the 24VDC constant output regardless of the input. We also need a minimum output of 25VA at 100RMP, and at about 300 RPM we need a 50VA output.The current design yields the following parameters:
100RPM 30VAC 40VDC (10HZ was measured on the AC side)
200RPM 60VAC 80VDC
300RPM 90VAC 120VDC
400RPM 120VAC 160VDC
500RPM 150VAC 200VDC
600RPM 180VAC 240VDC
700RPM 210VAC 280VDC
800RPM 240VAC 320VDC
I look forward to hearing from you very soon.
no
You may consider using our TopSwitch JX or HX for you design. But no reference design from us available for such a wide and very low minimum voltage input.
Is the output voltage required to be isolated from the input voltage?
