TOP SWITCH
Posted by: sreekanthr on
I am new to PI expert. I designed a circuit using Top Switch for the following Voltages
1. 24V @2A GND1
2. 24V@0.25A GND2
3. 15V@0.5A GND3
4. +12V@2A GND4
5. -12V@0.5A GND4
Feedback to TOP SWITCH is from +12V.
for reference i attachedPI expert file Also.
The circuit looks ok. and efficiency is about 92%.
Will it support for full loads on all supplies.
How reliable it is with full load.
What much be the components will get failure in future.
I want use this one in a VFD.
Plese clarify my doubts.
And suggest me the debugging procedure incase of failure.
regards
Sreekanth
Submitted by PI-Kenobi on 07/15/2013
All PIExpert designs are optimized based on the users specifications and should work fine under full load. Capacitors are usually known to have the shortest lifetime in a power supply. I would recommend performing an accelerated reliability/lifetime test on your power supply.
Submitted by sreekanthr on 07/15/2013
Thanks for the reply given.
What would be the minimum recommended load on feedback supply connected.
And can you recommend transformer manufacturers for this.
regards
Sreekanth
