planar transformer use in TFS design
Posted by: akasapa on
I want to use a planar transformer (not wire, nor foil but pcb type)  in my 28VDC 10A single output PS design with HiperTFS family. Does PI database have such a design example, guide or AN?
Submitted by PI-Tucker on 09/20/2012
Planar transformers are not recommended for 66 kHz designs.
They would be appropriate for 250-300 kHz.  Look up our HiperLCS (LLC controller) product for that.
Submitted by akasapa on 10/16/2012
which product should i use for 115V 400Hz input 28V 10A output with planar transformer and without PFC circuit?
Submitted by PI-Tucker on 10/17/2012
HiperLCS (LLC) running at 300+ kHz.
What is the input voltage range?
Submitted by akasapa on 10/17/2012
input AC voltage is 115VAC 400Hz within +-10% limit.
Submitted by akasapa on 10/19/2012
I do not have a hold up time requirement.
Submitted by PI-Tucker on 10/23/2012
Then the minimum input voltage for the LLC can be as high as 125 VDC.
