Non isolated feedback for GX family
Posted by: sijulal on
    Would like to know whether a simple divider network of 5.8 can be directly given to the control pin as feed back in case of non isolated designs using GX family devices.
Thanks & Regadrs
Submitted by PI-Surak on 07/27/2012
This is not recommended as this will give poor regulation since the C-pin pin controls as a function of current. It is better to sense primary aux feeback with a zener and low value resitor in series (12V zener with 100 ohm in series would be good) to keep tight regulation.
Submitted by sijulal on 07/27/2012
Thanks for the information provided. Could you please suggest any other way to provide feedback form the output side with out using an opto in the case of a non isolated requirement. As you said if we are sensing from the aux winding i am not able to get a very good regulation. What I need is to sense the output itself to provide a non isolate feedback. Please help.
Thanks & Regards
Submitted by PI-Surak on 07/30/2012
Those are really the only options for TOPSwitch. For winding feedback method you can improve it somewhat by closely coupling bias winding (feedback winding) near output winding layer
