LNK413 led driver
Posted by: ajith_vithanage
hi
i have made a sample led driver using lnk413
output voltage and current are 10.8V , .7A
i have a issue that once circuit is powered it takes 3 - 5 seconds to lit the LED s .
please help
thanks for the reply .please find the attached schematic diagram.
change c8 to 10 uf
i have changed c8 to 10uf .
but starting delay is there.
it takes 3-5 seconds to lit LED s after power on the circuit.
Place 240K, 0.5W resistor parallel to Diode D2....
replace C8 with 10uF,16V.....
replace R9 with 150ohms.....
R11 resistor not required remove it.....
Make sure you are using the right capacitor at the BP pin and the right values for your line peak detector connected to the V pin. If you like to post your schematic for us to take a look. Thank you.
