LNK413 led driver
Posted by: ajith_vithanage on
hi
i have made a sample led driver using lnk413
output voltage and current are 10.8V , .7A
i have a issue that once circuit is powered it takes 3 - 5 seconds to lit the LED s .
please help
Submitted by VCastrellon on 08/04/2011
Make sure you are using the right capacitor at the BP pin and the right values for your line peak detector connected to the V pin. If you like to post your schematic for us to take a look. Thank you.
Submitted by ajith_vithanage on 08/04/2011
thanks for the reply .please find the attached schematic diagram.
change c8 to 10 uf
i have changed c8 to 10uf .
but starting delay is there.
it takes 3-5 seconds to lit LED s after power on the circuit.
Submitted by kushal. u. s on 08/08/2011
Place 240K, 0.5W resistor parallel to Diode D2....
replace C8 with 10uF,16V.....
replace R9 with 150ohms.....
R11 resistor not required remove it.....
