LNK606 Shutdown
Posted by: pkeeler@powerb… on
Is it possible to disable the LNK606 by shorting the BP/M pin to the source (S) pin? Will this damage the part due to overheating of the internal 6V regulator? I am operating this part from a DC bus with a maximum voltage of 160V.
Submitted by Skywalker on 03/11/2010
The maximum BP/M pin charging current from the input is around 7mA at BP=0V.
If your maximum input voltage is 160VDC, the power dissipation in the device will be around 1.1W, and it is necessary to provide good thermal enviormnent to keep the junction temperature to be less than 150 deg C.
Submitted by pkeeler@powerb… on 03/11/2010
Thanks for your feedback Skywalker.
I'm only going to short the BP/M pin to source to shut down the LNK606 in the case of an abnormal fault, so if the LNK606 overheats and goes into thermal shutdown, that's OK. Do you know if the internal 142C thermal shutdown in the LNK606 shuts off the 6V regulator to prevent thermal runaway/failure in the event BP/M is shorted to source?
If there is no bias voltage due to shorted BP pin, there will be no over tempeature protection either.
I suspected that would be the case.
Thanks for your help.
Submitted by zxd414 on 03/12/2010
Can we shut down IC by keeping the Vfb below Vfb(AR)=0.65V?
If we pull down the FB pin.
