Transformer Parameters - Adding a new core to Component Library
Posted by: pentaindustrial on
I would like to add a new core and bobbin, but I have made some mistakes about the geometry of the core: Can you explain-me, through a picture if possible, the areas of the core? It´s very important add the new core and bobbin correctly for a sucessfull project.
I would like to know the meaning of the letters "AW", "BW", "LT", and "BFW"(see attached picture).
I´m in doubt about the material types also: What´s the difference between IP6, IP12R and HT50? The IP12R is more common than the others. Some of PI devices work with 300 or 400KHz. Can I use a core of the material IP12R for this work frequency, too? How can I proceed?
Thanks a lot!
Submitted by PI-Spock on 05/04/2009
There is a demo video on how to do add the transformer into the library. This video also explains the meaning of the parameters. Please visit
Click on the video that is titled "Adding a Custom Transformer into the Component Library"
Meaning of terms
AW - Area of Window (the shaded blue area in your attachment)
BW - Bobbin Width
LT - Length of single Turn
BFW - Bobbin Fit Window (This is a tough one to explai with words - see the video for this) It is the height available to wind so that core halves fit around the windiings. See the video... its explained better there.
Submitted by tmkaran on 05/06/2012
Hi all,
I watched the tutorial video for the adding custom transform. This si ice information. But I would like to toroid transform. So I misunderstand some parameters for this core. For example BW(Bobin width) parameters, How can I transform this parameters from sample "EE" core to "toroidal" core?
Unfortunately PI Expert does not support toroids...
