temperature measuring techniques.
to measure the temperature of switching devices we use a thermal camera. sometimes there are some differences between your(Power integrations) and our temperature measurement results. we are sure about the accuracy of our thermal cam. Which tech. do you use to measure temperature? What is the best technique to measure case temperature?
With the rapid penetration of Internet communication technologies across the globe, the possibility for individuals to seek out others for advice and know-how has dramatically increased. closet doors Individuals may now cross organizational boundaries to communicate efficiently with others regardless of time and space (Hinds & Kiesler, 1995). As a result, folding doors many organizations are in the process of implementing intranet-based communication tools, such as electronic discussion networks, to promote knowledge sharing across internal organizational boundaries (Alavi & Leidner, 1999; Davenport & Prusak, pet door 1998; Fulk & DeSanctis, 1995). Investments in these technologies are driven by the assumption that knowledge is the most valuable wood doors resource of the firm and that new knowledge is created through the recombination and exchange of existing knowledge (Kogut & Zander, 1992;
Hello phd.nash,
We do have three main measurement techniques for thermal evaluations. Function of size, power levels, and switching noise we use thermocouples, SMD thermistors, or thermal imaging. As soon as the power level, PCB copper areas, efficiency, air speed, etc. changes, the final result will be different. Even with two identical units it is possible to read different values. If that difference is 1%, 5% or more is a matter of instrument precision and ambient stability.
Cheers,
PI_Crusher
