LinkSwitch_TN Low-Side Buck-Boost – Optocoupler Feedback
I would like to know if anyone has successfully implemented a low-side Buck-Boost
Optocoupler Feedback design based on the LNK306. If so, can you share your schematics
GYH
I have implemented the circuit as shown in the attachment.
I am using the LNK306 device.
I cannot get any output and also C1 is blowing once we turn the power off.
Is the LNK306 the correct part for this design?
Is there some mis-wiring?
GYH
GYH
Change the value of C4 to 0.1 uF
The actual capacitor on the board is 0.1uF
GYH
You may check design idea 171, design idea 42 and AN 37 in the design support section of this webpage. Also PI exper software may help you with your low side buck-boost design.
Regards PI-worf
