LNK304 audible noise
Can you confirm your specification, both input voltage and output voltage and current.
The issue with a low inductor value is the larger di/dt (di/dt=V/L). If the input voltage is high then the current ramp can be fast enough that the peak current rating of the LNK304 is exceeded.
Cheers
PI-Chekov
I entered your spec into PIXls and 470 uH is marginal to deliver 60 mA, the recommended value being >545 uH (680 uH being the closest standard value). A 1 mH will also work but this is equivalent to designing for an output power of 1.32 W vs 0.72 W. As a result the average switching frequency will be ~30 kHz at full load and ~15 kHz with only the relay load.
I also noticed in your schematic that you have a 220 Ohm resistor in series with the input. For 220 VAC and 0.72 W of output power this should be fine but the DC bus voltage will be a little lower than calculated by the spreadsheet.
I'm still puzzled why you are getting significant audible noise.
Cheers
PI-Chekov
Just spotted that D2 is a 1N4007. This should be a UF4007, ie Ultra-fast recovery. This diode has the full input voltage impressed across it each switching cycle when the LinkSwitch-TN turns on.
Cheers
PI-Chekov
Cheers
PI-Chekov
Hi Zedman ,
did you found any solution for the same. i am also facing the same problem. i followed AN-37. for the the output 12V @ 160mA . used inductor Lin = 470uH and output inductor L = 1.5 mH. feedback diode is 1N4007 and also tried with UF 4007. Freewheel diode is BYV26C.
do anybody figured out whats the problem here ?
Pradeep
| 175-48069 (1).pdf (327.02 KB) | 327.02 KB |
Any troubles (2 yrs of exploatation). Yes SOME whispering noise is audible as well, when you only put your ear close to inductor (2..3 cm). But I hope it is not an issue for me for my cooler gives much more noice to hear... If you want I'll share my PCB design here.
Hi Alex,
for me sound is audible from 1ft . please share your pcb design. it would be a great help.
Pradeep
Hi Pradeep!
Here are three files schematic and PCB (both picture and source file). There is an area on PCB (at the bottom of a diagram) you do not need to fill with components (the thermo relay circuit cuts off LED string when heatsink's temperature becomes too high to operate). All the rest is the low power non isolated ACDC converter itself. Here we have about twenty specimens run quietly and happily for more than two yrs so far. )) Have fun!
Alex.
| schematic_diagram (58.67 KB) | 58.67 KB |
| pcb_diagram_picture (148.73 KB) | 148.73 KB |
| pcb_sprint_layout_60_source_file (12.54 KB) | 12.54 KB |
Thanks Alex.
into your noisy inductor. Take a disposable injector of 5 cm^3, pull out its piston, drop your inductor into empty barrel, pour isolating lacquer into the barrel (acrylic for instance)... Well, take a look at the picture for my Eng. is not good enough to explain the process distinctly... ))
Well, keep the piston pulled out for a couple of minutes (position #8). Then release, remove the cap (red), carefully push the gases emitted out from the barrel by pushing the piston slowly (in order not to pull out the lacquer - gases only), then put the cap onto the barrel's hole, then repeat vacuum treatment again. Do the cycle described several times. In the end pull out the piston, pull your vacuum impregnated inductor out from the barrel with a tweezers. Pour the lacquer out from the injector's barrel back into its can. Put the inductor into warm place and dry it carefully. Then drop it into your device. Your quiet happiness will come and will never go away. ))
| vacuum_impregnation.PNG (21.4 KB) | 21.4 KB |
Hi Pradeep,
Is your problem resolved? If not can you share your schematic and PIexpert/Pixls design file?
Can you also post it as a seperate question, since this post belongs to someone else?
PI-NANO
Hi PI-NANO,
my problem is resolved, just made on change in the design. observed that , when i output inductor , output capacitor and feedback diode. at a distance, there is no noise. made 3 boards and all working fine. dont k ow why but its working good for me.
Thanks all for the help.
That's good to hear that your issue resolved. However inorder to understand what was causing the issue in the first place, if you can send the Pixls design file, schematic, and PCB layout, I can review the design.
PI-NANO
Hello Zedman
Can you post the schematic? - I want to see which parts could be an issue. On the plus side our reference boards are quiet so there must be a culprit!
Cheers
PI-Chekov
