33V/800mA LED Driver problem
Posted by: maheshleo on
I made a LED Driver design using PIX Software.It is working fine.But,I had face the problem that it is not working while using Inverter.
Thank you in advance for your valuable reply
Submitted by PI-Dunwell on 02/13/2014
Which IC are you using. Please attach the schematic and pls send the waveform of the inverter.
Submitted by maheshleo on 03/02/2014
the above waveform is taken in X10 mode.please make a note of this.attached schematic also.We have used LNK419EG
Submitted by PI-Dunwell on 03/04/2014
For a square wave input, the output current can be different from the normal sinusoidal input. Pls confirm if this is the problem. For these situation, you may need to retrim your IFB if youre going to use an inverter .
Submitted by maheshleo on 03/05/2014
Hello sir,
we are using the LED lamp at 230V mains AC.if power failure occurs,we are using the square wave inverter.
It is working fine in Mains,but problem occurs in inverter only.
Is there any solution to use LED lamp in both?
Submitted by PI-Dunwell on 03/05/2014
Pls confirm what is the problem you see when you use an inverter. Is it regulation or something else?
It is visible Dim and Dip
Submitted by PI-Dunwell on 03/06/2014
Can you attach the output current waveform when using an inverter?
