no startup
Dear pi
i design non dimmable led driver for 48V and 1.1A output using LNK409 instade of LNK419 with refrence design DER290 but i face a problem driver starts for 2second and after it turn off more over in no load it gives 60V and drop down graguelly, Current at Fb pin is 112 micro amp. here i attach schematic, transformer & pi designer spread sheet.
thanks & regards
amit patel
Dear PI Crumb
thanks for your valuable replay, here i attached my schematic, transformer, and pi expert sheet
regards
amit patel
Please correct Q2 orientation.
Dear PI
Thanks for replay, After correction(remove ovp circuit) I got 54V at no load and 38V at load but current is 1mA more over I observe voltage is not appear(0V) and current is 26microA on FB pin. other parameters of all pins of IC is remains as datasheet, Now should i do for above problem. I am useing 27Kohms instade of 24.9Kohms resistor(for nondimmable) at R pin.
regards,
amit patel
Please re-connect the OVP circuit but you need to correct Q2 connection (the collector and emitter connection needs to be swapped, check RD290 for correct orientation).
What is your concern about No Load? Is it about the unit not latching? Please clarify what your problem is.
Dear PI
Thanks for your replay,
I reconnect ovp circuit and debug it as swapping Q2 now it is work, and gives output voltage 45V , and 0.79A, at this perameter Ifb is 195 microamp, now i want to increase o/p current up to 1.1A what should I do to increase o/p current?
thanks & regards
amit patel
Hi Amit,
I think the problem in your design could be
R5 + R6 = 3.909M
Rv2 = 1.402M (missing)
C5 = No use
R9 = must to be delete
Collector Emitter of Q2 interchanges
Please recheck with PI Engineer
Ravik
Keep C5 (to set full mode operation) and R9 (it's the pre-load for the bias supply and it helps reset the device faster during short-circuit condition). Setting R5 and R6 = 3.909M and using RV2 = 1.402M usually result is better line regulation but I don't think it's what causing the output current to be different from the spreadsheet. You may try to implement this though to see any improvement. Q2 connection needs to be corrected as previously mentioned. Please measure the actual IFB by measuring the actual bias voltage. [IFB = (Vbias-2.3V)/Rfb]. Adjust the feedback resistor accordingly. You may also use PIXLS spreadsheet to fine tune your design.
Dear Sir,
The start pin number of primary winding is ok?
I think it must be pin 3 please correct me if I am wrong.
Ravik
In the schematic, the primary winding orientation is indeed wrong. However, the transformer specification has the correct winding orientation that's why I did not point out the error in the schematic.
Dear sir,
Thanks for your valuable guidiance,
As your guidance I rectify all wrong connections (transformer as well as Q2, Rv2) and make it ok but problem is still there, mroe over I talk to our local PI adviser the LNK409EG/LNK419EG will not gives sufficient output power as my requirement whichi is 52W ( 48V and 1.1A) I have to go for higher capacity of device is LNK420EG but this device is not available at indian destributor, or if I operate device at it's maximum capacity (ifb=210microamp) can it make problem?
here I attach rectified schematic
thanks & regards
amit patel
IFB=210uA is too close to IFB skip cycle threshold. Try to maintain it below 200uA. However, please re-check your design against the spreadsheet. You should be able to get 1.1A with IFB <200 uA.
Try to increase bias capacitor to 22uF for lower ripple going to FB pin.
What is the actual bias voltage?
In the latest schematic you sent, R5 + R6 should be 3.909M since you put RV2 = 1.4Meg.
Please re-attach the files as I don't see them on your post. I can only guess at this point on why it might happen. If you based the design on RD-290, then please verify that the OVP circuit is designed properly. If not, it may cause the unit to latch. You may try to remove the OVP circuit and check if the unit can now startup normally.
At No Load, it is not unusual for the output voltage to shoot up since LNK-PH is not a CV controller. The OVP circuit is implemented to protect the driver from No Load condition.
