isolate source 20w output 78V/300mA for LED driver T8
Dear Sri,
We have 2 project for LED driver 20W and 10 W, Please kindly see detail below.
- First project input : 220Vac , Output voltage 78Vdc ,300mA 20W (T8)
- Second project input : 220Vac , Output voltage 78Vdc ,140mA 10W
- use PWM dimmable.
I would like to use LinkSwith - PH for this project, so would request give me the spreadsheet design start with the design.
Thank you & Best Regards,
Chalong
Dear sri,
Would you please help to check Schematic and spreadsheet design it's suitable or not?
Specification : Input 230V Output 68V280mA
Application : LED driver T8
Thank You & Best Regards,
Chalong
On your first post, the title mentioned about "Isolated Source". The attachments you just provided are for non-isolated applications. If you need isolation, please use flyback configuration using LinkSwitch-PH. I have searched some DERs to get you started for isolated T8 design. Please check DER256 and DER318. You can then create a PIXLS design based on LinkSwitch-PH Flyback topology and use these two DERs as reference.
For PWM dimming, please check this previous thread for some pointers:
http://www.powerint.com/forum/power-supply-design/can-i-perform-pwm-dimming-using-linkswitch-ph
If it's PWM-Analog dimming, then refer to DER263.
Kindly utilize the PI-Expert/ PIXLS Designer 8 for your design. Please check DER-263 for pwm dimming.
