Troubleshooting INN3688-H302 (DER-1024) – No Switching or Output Voltage
Posted by: Shepherd Simukonda
Dear Power Integrations Team,
We are working with the INN3688-H302 and referencing the DER-1024 design. After implementing the circuit on a custom PCB, we are encountering the following issues:
- No output voltage on the secondary side.
- No switching observed across the Drain-Source terminals.
- The BPP pin voltage is 5.388V.
- No voltage is present at the uCC pin.
The InnoSwitch3-Pro datasheet does not provide detailed information on expected operating voltages or fault detection mechanisms.
We would appreciate guidance on:
- Recommended debugging steps for this IC.
- Expected voltage levels at key pins.
- Any additional documentation or troubleshooting guides beyond the datasheet.
- Clarification if the chip needs any pre-programming before interfacing with the IP2738
If there are any resources available to assist in debugging this issue, please let us know. Your support would be greatly appreciated!
Hello Shepherd Simukonda,
I see that you have already raised a case with the same topic through our other portal. You should already be receiving support there.
You may also ask for information here, but the answers provided will most likely be the same.
Since communication has already progressed through the other portal, I recommend continuing support there.
