RCD + Z should TVS be uni or bi directional
I have made the attached design in PI Expert online.
The TVS in the RCD + Z snubber was chosen by PI Expert as a bidirectional TVS, is this correct?
In the schematic VR1 is shown as a unidirectional.
What is the correct type TVS to choose?
I don't knw why PI Expert is assigning a bidirectional TVS for the primary clamp - I'll bring it up with the web team. A unidirectional device is the usual option for the primary clamp, and likely less expensive as well.
When selecting TVS diodes for RCD circuits, whether they should be uni or bi-directional depends on the specific requirements of the application. sling billing issues Uni-directional TVS diodes protect against voltage spikes in one direction, while bi-directional TVS diodes safeguard against spikes in both directions. Consider the polarity of potential transients and select TVS diodes accordingly to ensure effective protection against overvoltage events in the RCD circuit.
If you are needing to clamp negative-going spikes with a bidirectional TVS, then the transformer design is seriously compromised, likely due to excessive intrawinding capacitance on the primary. Adding a damping resistor of a few tens of ohms in series with the clamp helps to damp excessive ringing due to stray capacitance.
Typically unidirectional, but a bidirectional TVS would work similarly for our purpose. In this case, the chosen bidirectional TVS would just operate as if its unidirectional, and it won't operate in the other region due to diode blocking.
