Low Input Voltage Operation using InnoSwitch3-EP
Posted by: Shahil Din on
I'm encountering a design issue with my switch-mode power supply  that utilizes the InnoSwitch3-EP (INN3678C). The SMPS powers up and outputs the required V when the input voltage is  133VAC or higher, under full load conditions (drawing 3A), but I'm facing problems when trying to achieve reliable operation within a lower input voltage range of 85VAC to 110VAC at full load.
When I change the input to a lower voltage e.g 100VAC it does not power up.  Note: The input type was selected as Universal in the PI Expert.
Things I have tried.
  • Tried different combination of undervoltage sense resistor, still no result the minimum stayed around 130VAC.
  • Shorted the undervoltage pin to source so it disables it. The minimum input AC at full load 3A was 150VAC.
  • Measured across C8 on the primary bias and I can see it was fluctuating until the input AC reached ~130VAC. Then It was 15V
Any insights, suggestions, or advice related to this  would be greatly appreciated.
Submitted by PI-Jedidiah on 09/13/2023
Can you share the PIexpert or PIxls file that you used?
Jedidiah
Submitted by Shahil Din on 09/13/2023
I have added the file as requested.
12V,3A.uds (533 KB) 533 KB
Submitted by PI-Jedidiah on 09/18/2023
Can you try to measure that switching waveform across Drain to Source of InnoSwitch? Also, can you share other waveforms that you took during low input voltage problem?
Jedidiah
