Feedback Design
Posted by: Arindam on
I am reading the application notes of TinySwitch 3 family design guide (pdf is given in the attachment). In the TL431 feedback design section a table is given, where different feedback components can be selected for different output voltages, but no generalized formulae or procedure is given. Where can I find some generalized formulae or procedure for feedback design of SMPS?
Arindam
Submitted by PI-ZBDelta on 11/18/2022
Hi Arindam,
You can use the voltage divider formula to solve for the value of Rs1 given the desired Vout (Rs2 is always 10kΩ).
The target voltage is set at 2.5V - TL431 reference voltage.
2.5 = (Vout * 10kΩ) / (10kΩ + RS1)
Submitted by Arindam on 11/19/2022
I understand, but how I design Cfb2, Rfb1, and Rbias?
Submitted by PI-ZBDelta on 11/23/2022
Hi Arindam,
100nF Cfb2 is recommended so that TL431 does not respond to the cycle-by-cycle output ripple voltage.
Rfb1 is designed to limit the feedback current through Ufb1.
1kΩ Rbias provides the minimum operating current of TL431 which is approximately equal to 1 mA.
