Variable output power supply
Posted by: atulbhakay on
Hi ,
I want to design a power supply with following specs
Input = 100VAC to 265VAC
Output = 0V to 5V variable output and current is 5A
Can I use a potentiometer (pot) in pace of the fixed resistor used in the TL431 circuit (the resistor that is connected to secondary return) and get a variable output voltage ?
Kindly advise
Atul Bhakay
Submitted by PI-Dumbo on 08/03/2021
Hi Atul Bhakay,
Can you send the schematic of the design?  Thank you.
