LNK304PN Output Voltage Goes UP
Posted by: PROMETHEUS
For direct feedback designs with <3mA minimum load using LinkSwitch, a pre-load resistor is required to maintain regulation. It is calculated as Vo/3mA and the value can be increased depending on the desired regulation. See Application Note AN-37 LinkSwitch-TN Family for futher details.
Thank you so much ZBDelta,
Problem solved with 1.5K resistor I didn't know about Vo/3mA , My load resistor was 3.2K
https://klasresim.com/i/wIVUms
https://klasresim.com/i/wIVB9M
