H301 vs. H302, InnoSwitch3-Pro
Posted by: ex on
Dear Sir or Madame,
we are currently checking INN3366C for a new offline charger design and are wondering about the versions H301 and H302 and the hint in the datasheet, that it's recommended to use H302 for new designs. Unfortunately INN3366C-H302 is not available today and we are wondering what are the differences and if it's possible to start with H301 and switch to H302 later? I read something about a discharge resistor at SR, a H-code that is responsible if the device is latching-off or in hysteresis mode and to be honest, I'm confused if it's only a improved replacement of if the behavior is different.
Thanks and Regards,
DH
Submitted by ex on 07/02/2021
Hi together,
we like to start with H301 and switch depending on the availability to H302. Will this be possible?
Submitted by PI-PIke on 07/06/2021
Hi etatronix,
The only difference is H301 has no output short circuit protection. Yes it is possible to start with H301 and switch to H302.
PI-Pike
