copper foil width calculation of transformer regarding secondary side
Posted by: Nizam Rony on
Dear Concerned,
I have been designing 150W 24V SMPS using PI expert. In Transformer Construction tab at Material section I found the width of copper foil is messing (Kindly check the attachment). And kindly tell me What formula should i use to calculate copper foil width on transformer construction for secondary?
Thanks in advance
Submitted by PI-Yoda on 05/26/2021
Hi, Nizam
I cannot find the attachment. Please attach the picture so I can have a look, or share a link to your design on piexpert@power.com, attention to PI-Yoda.
Basically, the foil width should be equal to the coil former width minus the safety margin required for the particular design and winding stack conditions.
Best Regards
Hi, Nizam
Thank you for sharing the attachment with us. It confirms that the foil width text is scrambled for some reason.
In the same time it looks like you are using a old standalone version in PIExpert.
In the latest 10.3 version and the online one  for the secondary winding instructions for this design:
Secondary Winding
Use 3 mm margin (item [8]) on the left side and 3 mm margin on the right side. Use 3 layers of tape for the foil insulation both sides around the edges which together with the margins are providing a total of 6.40 mm minimum of creepage and clearance to any primary part.
Start on pin(s) 7 and wind 3 turns of item [7]. Winding direction is clockwise. Finish this winding on pin(s) 6.
Add 3 layers of tape, item [3], for insulation.
The formulas are:
FoilWidth = CoilFormerWidth - SafetyTape - 3TapeThickness
SafetyTape = 6.4mm - FoilCornersTrippleIsulatedLength - 3TapeThickness
3TapeThickness could be considered approximately = 0
Please check the drawing provided
Please update your standalone version of PIExpert and let me know if something is not clear.
Submitted by Nizam Rony on 05/28/2021
Dear Concerned,
Here I attach my design file with design consideration and specification that I have used in PI Expert. And I have been using PI Expert 10.3.
I am so pleased with your support.
I have some confusions on secondary side.. where you recommend " Start on pin(s) 7 and wind 3 turns of item [7]. Winding direction is clockwise. Finish this winding on pin(s) 6".
But PI Expert 10.3 that I have been using suggest me the following:
"Secondary Winding
Use 3 mm margin (item [8]) on the top and 3 mm margin on the bottom (to meet safety). Start on pin(s) 12 and wind 5 turns of item [7]. Winding direction is clockwise. Finish this winding on pin(s) 10. Add 3 layers of tape, item [3], for insulation."
N.B Here I use Pin 12 and 10 as my secondary output for taking advantages during routing on PCB.
Basically My confusion now on calculation and  number of turns. I hope you understand what I mean. Please kindly check the attach project file. I need your kind support for finding the issues in this regard. As I am Noob using PI expert.
And also for item 7 my consideration is below (is it ok?):
Copper Foil: 5 mil thick,  11mm wide, covered with 1 layer of lapped tape. Terminations to foil: 2 x 23 AWG magnet wire with sleeving..
I also try PI_Expert Online which Project file also included as 2nd attachment.
Thanks in advance
SMPS_150W_24V_20_05_21.uds (543.5 KB) 543.5 KB
Pi_expert_online_150W_24V.uds (2.31 MB) 2.31 MB
Submitted by PI-Yoda on 05/29/2021
Hi, Nizam
To clear the confusion, my example of the secondary winding instruction - pins 3,7 and 3 turns is may creation of generic 24V/150W design. I have created it to check the winding instructions ONLY, without to know you particular specification.
So, do not use the information from there. Use the information from your deign files.
About the foil width:
ETD34 coil former has a CoilFormerWidth = 20.9mm, Two times of  SafetyTape 3mm has been used, as per you file so,
FoilWidth = CoilFormerWidth - SafetyTape  = 20.9mm - 2x3mm = 14.9mm  could be used.
For safety:
It must have 3 layers of tape 20.9mm wide before and after the foil
Minimum of 3.4 mm length of each foil corners must be covered with 3 layers of tape. So, the tape used must be min 6.8mm wide and it must be used centered to the edge,
Internally, and externally both foil leads must be isolated with sleeves providing creepage and clearance as 6.4mm. So, the total single sleeve length is 12.8mm
Please see my picture above.
Submitted by Nizam Rony on 05/29/2021
Dear Concerned,
Now its clear and Thanks for your kind support.
Submitted by JGE on 06/24/2021
Hi Pi-Yoda,
I have a question about this setup for the copper foil. It is really necessary to add the 3mm margin on left and right side?
Could be design in the way that there is no 3mm margin and the three insulation layer on  the foil corners covers unless 6.4mm in each side?
Jesús
Submitted by PI-Yoda on 06/25/2021
I am not sure I understand the question.
The 3mm margins are not mandatory. It is mandatory though, to maintain the minimum creepage and clearance as required by your safety standards.
If IEC60950 is considered, for the voltages in offline flyback converter this distance is min of 6.4mm. The actual actual safety margin implementation requirements are also explained in the standard.
Hi PI-Yoda,
Thanks for your reply.
You wrote "The 3mm margins are not mandatory. It is mandatory though, to maintain the minimum creepage and clearance as required by your safety standards."
Assuming 6.4mm neccessary for creepage, I attached a picture that shows two different ways to get this requirement.
The second one without margins so the copper foil can be wider. Because a three layers insulation is used, no minimum distance through insulation is required and the creepage is kept over 6.4mm. Therefore, I think it is a valid setup regarding safety.
I would appreciate read your though about it.
Jesús
Correct, it is a valid implementation without safety margin.
