about the judgment of the starting voltage of INN3279C.
Posted by: shima
Please tell me about the judgment of the starting voltage of INN3279C. INN3279C is configured to start when the current flowing into the UV / OV terminal exceeds the starting current (IUV +), but if this starting current fluctuates by about 100Hz, INN3279C determines at what timing the current can be started. Is it?
thank you for your answer. It was a misunderstanding here. I am sorry.
Hi Shima,
Thanks for your interests in Power Integrations GaN devices. With regards to your question I want to know if you are referring to fluctuating output load current?
