AC to CC design (Iout = 30A , Vout = 3v max )
Posted by: Youcef
I want to make 4 outputs to charges 4 supercapacitors of 1000F 2.7V with a fixed current of 30A from high line , so I need 4 outputs of a fixed current 30A and Vout varies from 0 to 3V
so I want to know what topology would suits my application .
Thank you for your reply ,
Can I use 4 isolated flybacks instead ? and what do you think about using InnoSwitch3-Pro for each ?
Can I use 4 isolated flaybacks instead ? and how about using InnoSwitch3-Pro for each ?
and I also want to know what modifications I should make on RDK-641 board to get 3V 30A ?
Hi Yousef,
For your application you will need to have an isolated converter such as a forward, flyback or resonant converter followed by four buck converters to independently control the power flow for each capacitor load. Unfortunately we do not have a DER for your application. Thanks
