PI Expert for designing my own Power Supply using LinkSwitch-XT2 (LNK6448K)
Please let me know that the circuit build by PI Expert Software is reliable or needs some modifications.
And I want to make 5V 2A 10W Power Supply for my Energy Meter but first check on PI Expert Software?
Hi, Imrnahmed,
Please use LinkSwitch-3 Flyback. It is only available in PIXLS. Select LNK64x8K and no cable compensation.
Than use the dark fields to enter your input parameters (spec) where they are different from the default one. On the end of the design check for error/warning/info messages and address the issues as per the help provided.
As a result, the component values and circuit parameters will be calculated and displayed.
Reliability could be calculated separately via MTBF and failure rate. It is mostly function of component parameters, frequency and temperature.
Dear PI-Yoda
Thank you for reply.
I am using PI Expert 10.2, in this, there is no option for Link Switch-3 Flyback in this software but option available in PIXI`s.Can you recommend me PI Expert software for LNK6448K deivce schematic maker.
Please find attachment.
Imran
| 첨부 파일 | 파일 크기 |
| PI.png (160.88 KB) | 160.88 KB |
Dear PI-Yoda,
I copied the data found in DER-403 document in PIXls and analyse that 99.95% values are matched but there is common issue INFO occur in both DER-403 and PIXls in KP Row.
How to fix it or it is not a big bug?
Imran
| 첨부 파일 | 파일 크기 |
| LinkSwitch-3_Design1.pixls (49 KB) | 49 KB |
| DER-403_LNK6448k_10W_5V_2A.pdf (3.81 MB) | 3.81 MB |
Hi Imran,
The Info in DER-430 drags your attention to the fact that is some conditions the circuit will enter CCM operation.
The value of the KP(current continuity factor) is very close to 1; PK=1 is boundary mode.
If you do have your own, particular reason you design to stay unconditionally in DCM than in next column is provided information about the places and the direction of changes needs to be done to drop KP value.
"Increase Cin, decrease DCON or use larger LYTSwitch-2 device"
Dear PI-Yoda,
Please let me know which one is better for power supply CCM mode or DCM mode?
Imran.
| 첨부 파일 | 파일 크기 |
| CCM-DCM_Kp.png (176.7 KB) | 176.7 KB |
Hi Imran, unfortunately there is no simple answer to your question, it is quite a topic.
The devil is in the details of the spec, objectives and design trade-offs. Using one of the modes is mostly aimed for achieving a particular tight target of the spec and usually goes with compromises in another area.
Without a deep knowledge over the impact of the current continuity over every aspect of performance my advice is to stick to overall average good design of Boundary Mode KP=1 (full load).
It is the same as the DER suggestion.
Dear PI-Yoda,
I want to add 3.3V winding in DER-403, please let me provide suggestion.
Imran
Hi Imran,
In AN-40 are instructions how to deal with second output in the design spreadsheet. Please find the link below.
If the design gets difficult maybe you can contact the local sales representative and the field applications engineer could provide a practical help or demos.. etc.
https://ac-dc.power.com/design-support/product-documents/application-notes/an-40-linkswitch-xt-design-guide/
Anybody here from Power Integration?
