TNY 289 OUTPUTS FLUCTUATIONS AND OUTPUT DROPS WHEN I DRAW THE CURRENT
Posted by: Tarun on
Hi PI Team,
Here I have designed a SMPS for the output of +18 and -18V with a current rating of 0.5A.
The output of the +18V varies from +22V to +25V and where as negetive output remains +25V stable.
When I connect the Load to the output the output suddenly goes to zero and keep variying.
Kindly suggest the solution. Here I have attached the schematic
Submitted by PI-Jedidiah on 07/31/2018
Hi Tarun,
You're schematic won't run. One of your output is in flyback condition while the other is in forward.
Jedidiah
Submitted by Tarun on 07/31/2018
Hi PI team
This schematic & transformer is designed using PI Expert suite.
Kindly tell me what are the corrections to be made in the schematic to make it work.
Submitted by PI-Jedidiah on 08/03/2018
Hi Tarun,
Let's try changing the regulator circuit. Attached here is the schematic for TL431 for the modified secondary circuit.
Jedidiah
