High Power SMPS for Battery Charging
Posted by: katte swaminath on
I am going to design a SMPS for battery charging with below given specification. Please suggest suitable PI part and design guide for the same.
AC Input Voltage Range 170-300VAC
Ac Input Voltage Nominal- 230VAC
AC Input Frequency 47-53Hz
DC Output Voltage - 65V +/- 0.5V
DC Output Line and Load Regulation - +/- 2%
Protections- Over load , Output Short Circuit, Over Temperature, Battery reverse, Boost Charging Safety timer,
Thanks and Regards,
Swaminath
Submitted by Easy Peasy on 02/01/2018
Output current? power?
Submitted by PI-LeoDavinci on 02/02/2018
Hi Swaminath,
May we please inquire what is the output current or output power requirement? Thank you very much.
Leo
Submitted by katte swaminath on 04/02/2018
The required output current is 6A
Submitted by Easy Peasy on 04/03/2018
At what DC o/p voltage?
Submitted by Ravi Adhyaru on 04/04/2018
I am going to design a SMPS for power supply with below given specification. Please suggest suitable PI part and design guide for the same.
AC Input Voltage Range 85-265VAC
AC Input Frequency 47-55Hz
Required O/P
10VDC / 20W/ 3 Amp
Kinldy suggest the best curuit of provide us TOP IC no.
Ravi Adhyaru
+91-9016496134
Required O/P
10VDC / 20W/ 3 Amp
Ravi Adhyaru
+91-9016496134
Submitted by Easy Peasy on 04/14/2018
10VDC and 3 amp is 30 watts out, not 20. There appear to be many design solutions listed on the PI website ...
Submitted by PI-LeoDavinci on 04/16/2018
Hi Ravi,
Just to clarify, you are designing a 20W and not a 30W SMPS right? For a 20W design you may try TOPSWITCH family of IC. For 85VAC-265VAC input voltage, you can can consider TOP258PN. Below is the link for the datasheet:
https://ac-dc.power.com/sites/default/files/product-docs/topswitch-hx_family_datasheet.pdf
For a reference design you may check the following link:
https://ac-dc.power.com/sites/default/files/PDFFiles/der188.pdf
Now , in order to cater for your particular specs and design you may want to try our design tool in the following link:
Just kindly sign up for if you are a new user. Hope this helps.
By the way what application are you targeting for this design? Thank you very much.
Leo
