Design 200W flyback AC/DC(24V/8.5A) by using TOP271
Hi!
I want to design a 200W flyback AC/DC(24V/8.5A) by using TOP271.Is it possible for PI's device?And I want to use PQ3220 transformer,but I can't find it in "PI Expert Online",so can help me get a design file on PQ3220?Finally,the attatched file is my design file,I want to use PQ3220,3Q!
Thanks,maybe you can give a better choice.hmmmmm,about PQ3220 for 200W?
ETD44 ...
Hi Peter Wang,
You can check in PIXls with link below if you wanted to verify your selected core if it is possible for your design requirement. If your selected core is not in the selection, you can just select custom and enter the specs of your selected core. Hopefully it helps. Thank you.
| 첨부 파일 | 파일 크기 |
| Custom_Transformer.png (57.17 KB) | 57.17 KB |
Thank you very much,Mallora!
To get 24VDC out at 8.5 amp even the TOP-250 would be marginal unless done as a forward converter.
The on resistance of the TOP-271 is 1.8 ohm worst case at 100C, just over 5 amp capability.
For Vin ave = 280VDC say the ave input current is ~ 0.9A and the peak current ~ 3.6 A in a properly designed flyback. The peak output current is ~ 34 amps, quite a bit.
The dissipation on the TOP-271 would be 4 watts just from conduction losses + switching losses - say another 2W = 6W so good heatsinking required
Also the Tx must be very low leakage to reduce turn off energy on the primary < 1uH, else your turn off snubber will need to handle ~ 5W ( for 1uH Llk )
A forward converter with moderate output L would be the way to go ...
good luck
