Power supply only with the live wire.
Posted by: Sami on
For a new project i need to generate 5Vdc from a 230Vac ( or universal 90..260 Vac ) supply with only the live wire and no neutral.
The module will be powered by the Live and  the load wire as you see in this example below.
live                      Module                       load         Neutral
[ ----| power and command module |----( load )-----]
I Load : 5A Max ( 1000W )
Thank you for your suggestions and help
Sincerely
Sami
Submitted by Sami on 03/28/2017
No one have any idea !
Sincerely
Sami.
Submitted by PI-Picard on 04/10/2017
Hi Sami,
Thank your for your inquiry. Can you send a more clearer connection diagram?
PI-Picard
Submitted by Sami on 04/20/2017
Hello PI-PICARD,
Thank you for your reply, you can see a better diagram under the attached picture.
Sincerely
Sami.
Submitted by PI-Picard on 04/22/2017
Hi Sami,
The load is a 1000W lamp that is in series with the "N" input of the power supply right? The 5V output of the power supply will provide input to the electronic circuit.
If the switch turns on this will short out the input of the power supply hence turning it off?
Can you explain how that configuration will work? What is your requirement?
PI-Picard
