24V 50W design example with low standby power <200mW
is there an design example for an power supply with 85V to 265V AC input and 24V DC 50W output with very low standby power <200mW available from power integrations?
Yours, Stefan
Hi PI-LeoDavinici,
i would like to use it as a power supply for a stepper motor drive in a small home application.
Hi Stefan,
You may want to consider the following designs using Power Integrations LinkSwitch or TopSwitch products. You may modify the design a little bit to satisfy your requirement. Hope this helps as a starting reference. Thank you very much.
LinkSwitch reference designs:
https://ac-dc.power.com/sites/default/files/PDFFiles/der453.pdf
https://ac-dc.power.com/sites/default/files/PDFFiles/der581.pdf
TopSwich reference designs:
https://ac-dc.power.com/sites/default/files/PDFFiles/der566.pdf
https://ac-dc.power.com/sites/default/files/PDFFiles/der243.pdf
Hi Stefan,
May we know what application your design will be used? Thank you very much.
