more 100V
Posted by: dgvol
whether it is possible to use a PI chip with an output voltage of more than 100V
TNY280, output 1-200v,0.04A;2-200v,0.04A
Do you have two outputs of 200 V? What's your input specification?
Yes 2 output 200V. Uin=150-265V
Attached the Transformer spreadsheet for the spec's you mentioned. And also please go through link-Switch TN Design guide and data sheet, The transformer spread sheet is designed using Flyback topology
| 첨부 파일 | 파일 크기 |
| LinkSwitch-TN Flyback Design_Forum.pixls (48.5 KB) | 48.5 KB |
Yes it is Possible.What kind of toplogy you are using? What are your Input and Output Specifications.
